Technical Forum
Error setting Cookie from iRule SIdeband
Shyam_Shukla
Hello All,
Requirement: After SAML authentication (configured in per-session policy), F5 should be able to call our custom HTTP service running at remote server. Our custom service sets one cookie (app_cookie) and which should be passed to user's browser by F5.
To implement above requirement, I Implemented following Sideband iRule which is called from iRule Event (from per-session policy).
This iRule reports below when code line "Set-Cookie ${val}" is executed.
<ERROR>
Aug 19 20:43:36 xhd-tvapf5poc01 err tmm3[11138]: 01220001:3: TCL error: /Common/RemoteCallForPartnerApps <ACCESS_SESSION_STARTED> - invalid command name "Set-Cookie app_cookie=HelloWorld!; Domain=.company.com; Expires=Tue, 20-Aug-2019 00:43:36 GMT; Path=/"    while executing ""Set-Cookie ${val}""    ("foreach" body line 7)    invoked from within "foreach {nam val} $headers {            log local0.debug "nam is $nam"                         log local0.debug "val is $val"                     i..."
</ERROR>
when ACCESS_SESSION_STARTED {
#using HSSR super sideband irule
log local0.debug "Entered sideband irule"
set sts [call /Common/HSSR::http_req -uri "http://<REMOTE_SERVER>/service" \
 -rcookies cookies -rheaders headers -state hstate]
   if { ([lsearch $cookies "app_cookie"] >= 0) } {
       log local0.debug "cookies is $cookies"
       #pass server cookies to client
           if {[string tolower $nam] eq "set-cookie"} {
             "Set-Cookie ${val}"
             break
Appreciate your help to troubleshoot this issue or suggest anyother option to implement above requirement.
Thanks,
Shyam
1 REPLY 1
"Set-Cookie ${val}" is not a valid command. There must be a statement at beginning of the line.
Link: HTTP::cookie
