M_Cheung_59761
Oct 10, 2006Error Handling
Does the API consist of a list of error codes specific to the FirePass SSL VPN Client itself? Or will it simply return the standard HRESULT values when encountering runtime errors?
- Jared_Townsley_Historic F5 AccountWindows HRESULT values are returned. These are documented in the SDK documentation for each method.
--JST - M_Cheung_59761
Thanks for the information! I will look them up in the SDK documentation.
