Yu_Li's avatar
Yu_Li
Sep 13, 2009
Error 404
After login the firepass..
Want i remote access the the PC..
It print a error..
Error code: 404
Description: ErrorL Firepass server could not handle the request.
Reason: Unable to find server port and address.
Please help, Thank you very much.
  • I was unaware you can customize the error message. You can however use a Big-IP Irule to change the text.
