karthik_sriniva's avatar
karthik_sriniva
Oct 18, 2005
Encrypt Command
Hi guys,
I am trying to encrypt my cookie using HTTP::cookie encrypt command. It works fine, but it affects performance. Without encryption page loads in 0.6 seconds. But with encryption it takes 3 seconds. Is there way to optimize the encryption. Would greatly appreciate your help
Karthik
  • rapmaster_c_127's avatar
    rapmaster_c_127
    Historic F5 Account
    There's simply no way BIG-IP will block a connection for 3 seconds! The microkernel has a completely non-blocking architecture, and the system just wouldn't be able to handle going out to lunch for 3 seconds. There's something else wrong here. Please could you post your rule, and we'll try to reproduce this.
    Have you contacted support/obtained tcpdumps?
  • You are right. BigIp kernel is not blocking the request.
    If a page has 10 images then my script is run 10 times. Running decrypt command 10 times is the problem. Some of the page have even more images.
    I meant to ask is there a way to have a static key and not generate the key for each request and use this key to encrypt and decrypt. By key I don't mean the passphrase.
  • This is script
    when RULE_INIT {
    when CLIENT_ACCEPTED {
      Define cookie variable and is Authentication page isLoginPage variable
      set cookieName "GTWLogin"
      set usernameCookie "GTWUSER"
      set cookieTimeout 15
      set username ""
      set userpwd ""
      set isLoginPage ""
      set cookieEncPwd "1400"
      set setUserCookie 0
      Define processing variables
      set runRadiusAuthentication 1
      set setCookieDuringResp 0
      set setModAuthHdr 1
      set redirectInd 0
      Logging condition
      set debugon 0
      Define protected Uri
      set protectedUri "/ll/"
      Define unprotected Uri
      set unprotectedUri "/llsupport/"
      set loginImgUri "/gtwlogin/"
      set unprotectedPage "/gtwlogin/calograd.htm"
      Define Radius Authentication identifier
      set asid [AUTH::start pam default_radius]
      set performAuthId "cGVyZm9ybWF1dGgubWVkaW5zdC5jb20"
      Define identifier to choose if login script to be run
      set runCustomLogin 1
      set isImageUrl 0
      Define logout Uri
      set logout 0
      set logoutPath "/cmd/ICSLogout"
      set logoutPage "/gtwlogin/gtwlogout.htm"
       Retrieve all required values
       set cookieDomain [HTTP::host]
       set cookieExists [HTTP::cookie exists $cookieName]
       set ckvalue [HTTP::cookie value $cookieName]
       set requestedUri [HTTP::uri]
       set requestedPage [HTTP::path]
       If requested page is logout command ICSLogout
       if { [HTTP::path] eq $logoutPath } {
           set logout 1
           set runCustomLogin 0
           set setModAuthHdr 0
       If requested page is logout page
       if { $requestedPage eq $logoutPage } {
           set setModAuthHdr 0
       If request is for image
       if { [HTTP::path] contains $unprotectedPage || $requestedUri contains $unprotectedUri || $requestedUri contains $loginImgUri || $requestedUri contains ".png" || $requestedUri contains ".gif" || $requestedUri contains ".jpg" || $requestedUri contains ".jpeg" || $requestedUri contains ".css" } {
          set setModAuthHdr 0
       If requested page is protected
       if { [HTTP::uri] contains $protectedUri } {
       If cookie exists always run through login script
       if { $cookieExists eq 1 } {
          set runCustonLogin 1
       If the request if for protected uri
       if { $runCustomLogin ne 0 } {
          if { $cookieExists } {
             if { $ckvalue ne "!-100119899091" } {
                 HTTP::cookie decrypt $usernameCookie $cookieEncPwd 128
                 set username [HTTP::cookie value $usernameCookie]
                 set username $ckvalue
          set reqdata [HTTP::payload]
          check if it's post from login page
          if { $reqdata contains $performAuthId }
             set runRadiusAuthentication 99
       set tmpUsername [findstr $reqdata "username" 9]
       set username [getfield $tmpUsername "&" 1]
       set tmppwd [findstr $reqdata "password" 9]
       set userpwd [getfield $tmppwd "&" 1]
       set isLoginRequested [findstr $reqdata "bigipLogin" 11]
       set isLoginPage [getfield $isLoginRequested "&" 1]
          log "I am inside runcustomlogin ne 0 $runCustomLogin $runRadiusAuthentication $isLoginPage"
          check if cookie exists but the user had logout already
          if { $cookieExists eq 1 && $ckvalue eq "!-100119899091" && $runRadiusAuthentication ne 99 }
               set redirectInd 99
               set runRadiusAuthentication 0
          check if the session has timeout
          if { $redirectInd ne 99 && $cookieExists eq 1 && $runRadiusAuthentication ne 99} {
       set currenttime [clock seconds]
       set delta [expr $currenttime - $ckvalue]
       if { $delta > 15 } {
     set setModAuthHdr 0
             set redirectInd 98
             set setCookieDuringResp 1
           Run radius authentication if runRadiusAuthentication is set to one ||| no Cookie
           if { $runRadiusAuthentication ne 0 && $redirectInd ne 99}
                log "username $username "
                if { $username eq "" || $userpwd eq "" } {
                     set redirectInd 99
                log "About to call authenticate"
                if { $debugon eq 1 } {
           log "Abt to call auth"
        if { $redirectInd ne 99 } {
             log "About to call authenticate $username : pwd"
             set setModAuthHdr 1
             AUTH::username_credential $asid $username
             AUTH::password_credential $asid $userpwd
             AUTH::authenticate $asid
             if { $redirectInd eq 0 } {
                 HTTP::collect
        log "complete call to auth"
           set header for mod_auth_anon
           if { $setModAuthHdr eq 1} {
               log "inside mod auth $username"
               set ename [b64encode "$username:\$apr1\$Vk1.....\$fVfqXg8t8iFv.guKLPJdi0"]
               HTTP::header remove Authorization
               HTTP::header insert XAuthorization $ename
               HTTP::header insert Authorization "Basic $ename"
    when HTTP_RESPONSE {
       if { $setCookieDuringResp eq 1 } {
         log "setting cookie $requestedUri :: $isImageUrl"
         set cookieval [clock seconds]
         HTTP::cookie insert name $cookieName value $cookieval path / domain $cookieDomain
         HTTP::cookie encrypt $cookieName $cookieEncPwd 128
         HTTP::cookie expires $cookieName $cookieTimeout relative
         if { $setUserCookie eq 1 } {
             HTTP::cookie insert name $usernameCookie value [b64encode $username] path / domain $cookieDomain
             HTTP::cookie insert name $usernameCookie value $username path / domain $cookieDomain
             HTTP::cookie encrypt $usernameCookie $cookieEncPwd 128
             HTTP::cookie discard $usernameCookie enable
             HTTP::cookie expires $usernameCookie $cookieTimeout relative
       if { $redirectInd eq 98 } {
         HTTP::cookie insert name $cookieName value "!-100119899091" path / domain $cookieDomain
         HTTP::cookie insert name $usernameCookie value "!-100119899091" path / domain $cookieDomain
         HTTP::redirect "http://$cookieDomain/gtwlogin/caltimeout.htm"
       if { $redirectInd eq 1 } {
         HTTP::redirect "http://$cookieDomain/gtwlogin/calfail.htm"
       if { $redirectInd eq 2 || $redirectInd eq 99} {
         HTTP::redirect "http://$cookieDomain/gtwlogin/calograd.htm"
       if { $redirectInd eq 3 } {
         HTTP::redirect "http://$cookieDomain/gtwlogin/calerror.htm"
       if { $logout eq 1 } {
         HTTP::redirect "http://$cookieDomain/gtwlogin/gtwlogout.htm"
       when AUTH_SUCCESS {
               log "AUTH CALLED"
           if { $asid eq [AUTH::last_event_session_id] }
               set setUserCookie 1
               HTTP::release
       when AUTH_FAILURE {
               set redirectInd 1
               HTTP::release
       when AUTH_WANTCREDENTIAL {
              log "WANT CRED"
               set redirectInd 2
               HTTP::release
       when AUTH_ERROR {
               set redirectInd 3
               HTTP::release
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    Try:
    when RULE_INIT {
       set ::key [AES::key]
       set decrypted [HTTP::cookie "MyCookie"]
       HTTP::cookie remove "MyCookie"
       set encrypted [b64encode [AES::encrypt $::key $decrypted]]
       HTTP::cookie insert name "MyCookie" value $encrypted
       set encrypted [HTTP::cookie "MyCookie"]
       set decrypted [AES::decrypt $::key [b64decode $encrypted]]
       HTTP::cookie insert name "MyCookie" value $decrypted
    I am also worried about your use of the "clock" command unless you have upgraded to 9.2.
  • I want to point out that this (old) iRule would cause all cookies to be corrupted in a reboot or failover event. I highly recommend using the newer "HTTP::cookie encrypt" command.
