26-Sep-2023 13:15
Hi Folks, we are in a process of deploying F5s in a VmWare environment. We will have them only licensed for LTM. My question is what .ova file am I downloading here?
BIGIP-17.1.0.3-0.0.4.ALL-vmware.ova
OR
BIGIP-17.1.0.3-0.0.4.LTM-vmware.ova
There could be a future use case to apply a APM license key, so will it be the ALL.ova?
Solved! Go to Solution.
27-Sep-2023 04:09
Hi Sandy,
Yes, I would recommend using .ALL because you might use any other F5 module in the future. so instead of intiailizing any other ova files, you cna use the existing one already.
Thanks,
Mohamed Salah
26-Sep-2023 21:58
hope the below article will help you
27-Sep-2023 04:09
Hi Sandy,
Thanks,
Mohamed Salah
