24-Apr-2022 04:36
This apm logging is not working at all but only works when I also add the same syslog server to system - logs - remote logging....why??
I have created a publisher with a destination that has a HSL pool member in it and then I apply it to apm event logging ..
But nothing is sent to the syslog until I also go and add a remote logging server at the device level..
28-Apr-2022 12:40
Hi David_M,
I tested it without adding syslog server in system > logs > remote logging menu. Apm logs are forwarded to the hsl pool member.
Could you have selected the protocol in the log destination as tcp?
Can you review the packets?
tcpdump -nni any host hslpoolmemberip and port hslpoolmemberport
