dlogsdonmd's avatar
dlogsdonmd
Feb 25, 2016
Default Pool and iRules
Hello,
I have a default pool of servers assigned to a VS object and then also have an irule that specifies specific traffic (URIs) should be directed to different server pools.
How does the LTM treat all the traffic to the LB object? Does all traffic go to the configured "default pool" or is it inspected and then directed to the "default pool" only if it doesn't meet the criteria in the iRule? Our iRule is below and the last pool referenced is the same pool configured in the "default pool" on this object.
Thanks in advance.
Diane
 if { [string tolower [HTTP::uri]] contains "/pamspersonifywebservice" } {
   if {[active_members PAMS_PersonifyWebservices] > 0} {
      pool PAMS_PersonifyWebservices
      HTTP::redirect "http://maintenance.acc.org"
      event disable all
 elseif { [string tolower [HTTP::uri]] contains "/pamsrestservices" } {
   if {[active_members PAMS_RESTWebservices] > 0} {
      pool PAMS_RESTWebservices
      event disable all
 elseif { [string tolower [HTTP::host]] contains "webservices.acc.org" } {
   if {[active_members Webservices_RDWS] > 0} {
      pool Webservices_RDWS
      event disable all
 else {
      HTTP::respond 404 content "Unrecognized request to [HTTP::uri]" "Content-Type" "text/html"
