Erika_I_Garner's avatar
Erika_I_Garner
Feb 09, 2018
Default action in iRule is not being triggered. Help!
I am having some issues with the following irule, it works great when the cookie is present, however if the request does not have a cookie it gives me the log as if it already did have a cookie.
I should be seen the log " "[IP::client_addr]--cookie [HTTP::cookie value cookiecrisp] No Cookie Present - Go to default Pool" if the request doesnt have a cookie. Would you all be able to tell what am I doing wrong?
if { [HTTP::cookie exists cookiecrisp] } {
    switch [HTTP::cookie value cookiecrisp] {
        "901" { if { [LB::status pool P----QA-443 member  10.0.9.130 443] eq "up" } {
            log local0. "[HTTP::cookie value cookiecrisp] matched NODE S-S1Q to cookie 901"
            } elseif {
                [LB::status pool P----QA-443 member  10.0.11.131 443] eq "up" } {
                log local0. "[HTTP::cookie value cookiecrisp] NODE S-S1Q DOWN, sent to NODE S-S2Q "
                    pool P----QA-443
                    log local0. "[HTTP::cookie value cookiecrisp] NODE S-S2Q DOWN, sent to the pool
                    P----QA-443"
        "902" { if { [LB::status pool P----QA-443 member 10.0.11.131 443] eq "up" } {
            log local0. "[HTTP::cookie value cookiecrisp] matched NODE S-S2Q to cookie 902"
            } elseif {
                [LB::status pool P----QA-443 member 10.0.9.132 443] eq "up" } {
                log local0. "[HTTP::cookie value cookiecrisp] NODE S-S2Q DOWN, sent to NODE S-S3Q "
                    pool P----QA-443
                    log local0. "[HTTP::cookie value cookiecrisp] NODE S-S3Q DOWN, sent to the pool P----QA-443"
        "903" { if { [LB::status pool P----QA-443 member 10.0.9.132  443] eq "up" } {
            log local0. "[HTTP::cookie value cookiecrisp] matched NODE S-S3Q to cookie 903"
            } elseif {
                log local0. "[HTTP::cookie value cookiecrisp] NODE S-S3Q DOWN, sent to NODE S-S1Q "
     pool P----QA-443
            default {
            pool P----QA-443
            log local0. "[IP::client_addr]--cookie [HTTP::cookie value cookiecrisp] No Cookie Present -
            Go to default Pool"
Thank you for your help! -Erika
  • before the switch, you have this condition:
    if the cookie is not present, you can't go to the default statement.
  • Ok this look better
    pool P----QA-443
    log local0. "[IP::client_addr] No Cookie Present - Go to default Pool"
                } elseif {
                        pool P----QA-443
                        log local0. "[HTTP::cookie value cookiecrisp] NODE S-S2Q DOWN, sent to the pool P----QA-443"
                } elseif {
                        pool P----QA-443
                } elseif {
                        pool P----QA-443
