Sakkarin_Westco
Altostratus
Jul 15, 2021Data mask feature with layer2 transparent ?
I need to know F5 AWAF can use the data mask feature with layer2 transparent?
- Erik_Novak
Employee
AdvWAF can mask certain data in an HTTP transaction at layer 7. Think of payload data such as user credentials or other information that a client passes to a web application. What are you trying to mask?
- Sakkarin_Westco
Altostratus
Thanks, Erik. It supports layer2 and layer3 deployment, right?
- Erik_Novak
Employee
If I understand your question the answer is yes, BIG-IP supports layer 2 and layer 3. Advanced WAF only secures HTTP at layer 7. Does that make sense?
