unavailable's avatar
unavailable
Oct 31, 2022
Correlation Id
Hi team,
I need to configure correlation id on my F5 ver 15.1.2.
I read on internet that is possible to do it by an irule thaat the moment,  I have not found.
I ask to the community if someone help me to do it.
Many thanks in advanced for your time.
Tks,
  • unavailableif you can provide a bit more detail as to the exact data that you are trying to match I should be able to point you in the right direction. In most cases with HTTP/S traffic you just need to know the header you are looking for and pull the data out of it.
  • Hi Paulius,
    many thanks for your reply.
    At the moment the problem was resolved.
    Many thanks again.
    Rgds,
    • Leslie_Hubertus's avatar
      Leslie_Hubertus
      Ret. Employee
      unavailable - how did you solve your problem? Curious if it is a solution a future user with the same question may be able to use.
  • Hello,
    sorry for my delay to reply to you.
    The customer has not preferred to install this feature.
    Regards,
      Leslie_Hubertus
      Ret. Employee
      No worries, and no apology needed. 🙂
      Thanks for letting us know. May I ask what solution they went with?
