suthomas1's avatar
suthomas1
Dec 15, 2020
cookies
Good day all,
I am having some trouble with this irule about cookies. Not very much into irule hence can't get the full scenario here on what does this achieve.
Appreciate some assistance on what this rule is doing & how to check if its doing it .
when HTTP_REQ {
  set log_prefix "[IP::client_addr]:[TCP::client_port]"
  if { [HTTP::cookie "JSESSIONID"] ne "" }{
    persist uie [string tolower [HTTP::cookie "JSESSIONID"]] 5400
   set jsess [findstr [string tolower [HTTP::path]] "jsessionid=" 11]
   if { $jsess != "" } {
     persist uie $jsess 5400
when HTTP_RESP {
    persist add uie [string tolower [HTTP::cookie "JSESSIONID"]] 5400
Thank you in advance.
  • Hello Suthomas
    This iRule provides a way of using persistence by cookie (JSESSION). The behaviour is describe here:
    https://devcentral.f5.com/s/articles/weblogic-jsessionid-persistence
    Instead of using this iRule you can use a Cookie Hash using the same JSESSION as cookie name.
    ​https://support.f5.com/csp/article/K6586
    Or some other methods
    https://support.f5.com/csp/article/K83419154
    Regards,
    Dario.
