Vipin_131018's avatar
Vipin_131018
May 15, 2017
convert SSL X509::serial_number into decimal
Hi Team,
I have an irule to extract specific X509 information from client certificate and pass it onto servers. Irule is working as expected, but application has the requirement to convert X509::serial_number into decimal. Currently it is being send in default Hex format. Below is the iRule i am using.
when CLIENTSSL_CLIENTCERT { set ssl_cert [SSL::cert 0] set sn [X509::serial_number $ssl_cert] set subject [X509::subject $ssl_cert] set issuer [X509::issuer $ssl_cert] set valid_from [X509::not_valid_before $ssl_cert] set valid_to [X509::not_valid_after $ssl_cert] session add uie [SSL::sessionid] [list $sn $issuer $subject $valid_from $valid_to] 1800 }
when HTTP_REQUEST { set values [session lookup uie [SSL::sessionid] ] if { [lindex $values 0] != "" } { HTTP::header insert client_ip_address [IP::client_addr] HTTP::header insert client_cert_serial_num [lindex $values 0] HTTP::header insert client_cert_subject [lindex $values 1] HTTP::header insert client_cert_issuer [lindex $values 2] HTTP::header insert client_cert_valid_from [lindex $values 3] HTTP::header insert client_cert_valid_to [lindex $values 4] } }
  • Anesh's avatar
    Anesh
    Try the below
    set decimal [expr $sn]
    session add uie [SSL::sessionid] [list $decimal $issuer $subject $valid_from $valid_to] 1800
  • Or try to include something like this. I think the example above will not work, because the heximal representation of the serial includes the colon signs.
    set fields [split $sn ":"]
    set sn_decimal ""
    foreach field $fields {
        scan $field %x decimal
        set sn_decimal [concat $sn_decimal$decimal]
  • Hi,
    you can use this code :
        set sn_hex [X509::serial_number $ssl_cert]
         remove useless characters
        set sn_hex [string map {" " "" ":" ""} $sn_hex]
         convert hex to decimal
        set sn [expr 0x$sn_hex]
