02-Dec-2022 10:38
Hey guys, hope everyone is well.
I hope someone can help with this. I've set up a dozen or so RDP sessions via a URL. Users can log in and see the list of servers, but when clicking on a server, they get the attached error.
For the life of me, I cannot see what's missing. I'd really appreciate any assistance.
Many thanks
B
02-Dec-2022 11:09
Additionally, I see this on the logs:
Fri Dec 2 18:49:45 GMT 2022 | notice | lon-f5-01 | apmd[7856] | 01490005 | /Common/APM_ecrs.blpw.com:Common:76a0f81e: Following rule 'fallback' from item 'Resource Assign' to ending 'Allow' | |
Fri Dec 2 18:49:45 GMT 2022 | err | lon-f5-01 | apmd[7856] | 0149013e | /Common/APM_ecrs.blpw.com:Common:76a0f81e: Allow agent: Logon denied due to validation error, Error Code: 4001 (Zero resources assigned) | |
Fri Dec 2 18:49:45 GMT 2022 | err | lon-f5-01 | apmd[7856] | 0149018d | /Common/APM_ecrs.blpw.com:Common:76a0f81e: Resource validation for webtop '/Common/webtop-ecrs' failed with error type 'Zero resources assigned' |
Where can I add resources?
02-Dec-2022 11:54
Normally you would have to use advanced resource agent and assign an already configured rdp item to the session. The log message tells that you haven't assigned any item. What I couldn't understand is what do you mean by users can log in an see the list of servers? Can you share your vpe flow?
02-Dec-2022 12:13
02-Dec-2022 12:26
Any one of "ressource assign" or "advanced resource assign" agents should let you add the rdp items, make sure also you add the webtop item.
02-Dec-2022 12:29 - edited 02-Dec-2022 13:01
Hi Balcee,
can you please answer Amine's question what "Users can log in and see the list of servers" means? Do the webtop successfully load after login? Or is this already failing?
Cheers, Kai
