Concurrent SSL-Sessions & Visibility
a customer just asked a simple question, for which I couldn't find any information on the fly.
"How many concurrent SSL sessions can be handled by an i2600?" (not TPS!)
The TPS values can be found in the datasheet (2.5K RSA-2048), and also the max. L4 connections (14M).
I could only find an FAQ for the 1600/3400 models of a czech vendor, that shows these numbers that I'm looking for. (here)
The numbers for "Max. SSL Concurrent Connections" seem to correlate with the "Max. Concurrent Connections" by a factor of 1:8.
So for an i2600 (14M MCC) this would result in 1.75M MSSLCC. But that's just random guessing based on an unofficial(?) document...
Is there any official evidence or documentation/description for that?
Also, is it possible to monitor the concurrent SSL-connections in Dashboard or in any statistics? Cause I see the normal connections, and the SSL TPS, but not the concurrent SSL connections for the system...
Thanks in advance!
