suthomas1's avatar
suthomas1
Apr 26, 2021
Solved
cm changes
Good day all,
In our clustered big-ip, we have recently seen it showing changes pending.
There have been no changes done, it would only be one of the admin team members browsing to check something.
Will that changes pending in red cause any issues, it is prompting to sync the secondary with primary.
The other thing noticed is dates on changes pending on gui are not the same in tmsh.
Is there any way to see why bigip is giving this error & what pending changes is it referring to.
CM::Sync Status
Color  red
Status  Changes Pending
Mode   high-availability
Summary There is a possible change conflict between bigip-dev0 and bigip-dev1
Details
     bigip-dev1: connected
     bigip-dev-grp (Changes Pending): There is a possible change conflict between bigip-dev0 and bigip-dev1.
     - Recommended action: Synchronize bigip-dev1 to group bigip-dev-grp
Please help, thank you.
  • This would often happen if the engineers try to login to the standby & make some new changes. Or any config push done to the standby device.
    Try running this, it will show from the config sync started & if the commit id matches
    tmsh run cm watch-devicegroup-device
