StanI_87551's avatar
StanI_87551
Jun 08, 2015
Chrome (ERR_CONNECTION_RESET)
I have a developer who is experiencing an issue only with Chrome & here is his description:
I believe the issue is google chrome is throwing a connection reset error: (ERR_CONNECTION_RESET) with the F5 load balancer. I have not seen this error occur with Firefox or IE 11.
Which leads me to think it is only related to chrome.
I believe the issue is with chrome and the F5, because I can connect directly to the server using without issue.
In order to reproduce this error, I clear all history/cache/cookies etc. in chrome, and connect to our load balancer site Spotfire.aviallinc.com -- It connects without issue the majority of the time, however if I repeat this process of clearing history and re-hitting the website this error will eventually appear, usually within 5 or 6 cycles. -- The error will resolve itself, after a few seconds, sometimes within 1 sometimes up to 10, but in general it will correct itself and repoint.
The server for the load-balancer is a new version so I’m assuming the RFC5746 already exists? https://support.f5.com/kb/en-us/solutions/public/13000/800/sol13860.html
  • i think it may be useful if you can capture packet when issue is happening.
     tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x or host y.y.y.y or host z.z.z.z -v
    x.x.x.x is client ip
    y.y.y.y and z.z.z.z are pool member ip
  • StanI's avatar
    StanI
    Ran the trace looked @ the pcap file and most of the traffic is between F5 Float IP on the vlan the servers are on and the server (secondary server was Offline (Enabled)) so this is a single threadded VS_ to Pool_ to Server on port 443.
    Virtual Server:
    vs_spotfire.aviallinc.com_80
    Destination: 172.18.19.30:80
    with iRule = http_to_https
        HTTP::redirect https://[HTTP::host][HTTP::uri]
    Virtual Server:
    Destination: 172.18.19.30:443
    Pool: spotfire.aviallinc.com
    Pool Member: wspw-prd-1:443
    Pool Member: wspw-prd-2:443
  • StanI's avatar
    StanI
    Nothing that I can see, the capture from the F5 shows lots of duplicates
    62% of the tcp errors = Duplicate Acks
    22% of the tcp errors Retransmissions
    13% Resets
  • i would be worried about the 111 resets, specially if that happens we you see the issue occur, do they come from the client or the big-ip? you will have to bring those two things together and see if you can find a common cause. the logging shows nothing at these moments?
