Beinwin_264402's avatar
Beinwin_264402
8 years ago
Chrome err_connection_reset
We just create a new iApp with the wizard. All the health monitors looks fine so the pool is up and evrything appears that is working fine, but when we try to ingress to the new website we received en err_connection_reset. We ran an capture and we see that the VS is sending and RST. This happen with both plaintext and ssl offload.
Do you, what could be the issue?
Thanks in advance.
  • Oh! Is your back-end server is using any certificate? Plz check.. Apply 'insecure-servers' server SSL profile to vip. It will start working.. later tune server cipher.
    • Beinwin_264402's avatar
      Beinwin_264402
      Hi f5_rock. Thanks for your reply. No the server is not using any certificate.
      Regards!
  • Hi Guys
    I have the same problem on HTTP and https I get a connection reset after hitting my VIP url. if I access the site like 4-5 times I will get a connection reset on the 5th or 6th time. sometimes it will fix itself after a few seconds.
    Has anyone had this issue.
      Beinwin_264402
      Hi Lutha.
      At this moment I dont remenber how do we fixed it. But I think that was an issue with the wizard. Please try to create all the components (the vs, the pool, the monitor, the ssl profile, etc) one by one. I think that could you help you.
      Let me know if that works for you.
      Regards,
    • Hank_Moody_3649's avatar
      Hank_Moody_3649
      I have the exact same error here.. Always ERR_CONN_RESET after refreshing a few times it works, but is really sloooow. Why does F5 not have a solution for this?
  • Verify that the Backend Server(Pool Member/Nodes) know the source, the backend server has the route to the source otherwise "source address translation" to be set up.
    Source Address Translation: Auto Map
