Technical Forum
Changing samesite attribute on ASM TS Cookie
pinkzeppelin
Altostratus
Altostratus
Is there a way to add Secure; SameSite=none attributes on ASM TS cookies?
Thanks.
1 ACCEPTED SOLUTION
2 REPLIES 2
Paulius
MVP
MVP
Leslie_Hubertus
Community Manager
Community Manager
I see the kudo you gave to the reply, @pinkzeppelin, so I'm assuming the link @Paulius shared helped you out - so I'm marking it as the Accepted Solution. If it isn't, let me know so I can revert the status!
