12-Jul-2013 00:56
How can I change the partition in imish shell ?
I need to configure the different routing for different route domains in viprion chassis.
Which command should I use for the changing the routing domains in imish shell?
When I type imish, then I log on only domain 0, but I need to go another domain.
I hope, I managed to be clear about my point.
thanks a lot.
12-Jul-2013 01:00
4.Type this command: run /util imish -r ID. If the route domain for the protocol you want to configure is the default route domain for the current partition, you do not need to use the -r option to specify the route domain ID. This command invokes the IMI shell.Accessing the IMI Shell
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-ip-routing-administration-11-2-0/4.html
