Barry_Gavenda_3's avatar
Barry_Gavenda_3
May 01, 2019
Change Host header for each node in a pool
I need to change the host header on each pool member. IE the incomming host header is 1.site.com. I set up a pool of servers, but each needs to have its OWN host header. a.something.local b.something.local c.something.local I never want to advertise the .local hosts to the client, should all just be 1.site.com. What is the best way to achieve this?
  • Why does it have to have its own host header ? If the goal is for the server to take specific action based on the header, can you insert the header at the F5 instead of changing the host header ?
  • Hi Barry,
    Have seen these requirements in the past and there's been lot of solutions shared too. Don't want to reinvent the wheel, follow these links and you'll find the solutions,
    Rewrite Host Header to Server IP:port
    Rewrite Host Header to Server Name
    You'd have to create a Data Group and an Irule for this.
    Data Group:
    ltm data-group internal ip_to_host_dg {
        records {
            1.1.1.1 {
                data host1.example.com
            1.1.1.2 {
                data host2.example.com
            1.1.1.5 {
                data host3.example.com
        type string
    Irule:
    when HTTP_REQUEST_SEND {
       clientside {
          set host_header_value [class match -value [IP::server_addr] equals ip_to_host_dg]
          if {$host_header_value ne ""}{
             HTTP::header replace Host $host_header_value
    Again you can modify the host header for the http response back to the client. hope this helps.
  • Hi,
    try this:
    You just need to modify IP by your backend IP and needed host.
    when LB_SELECTED {
    if { [LB::server addr] eq "10.1.1.1" } {
        set host "1.site.com"
    } elseif { [LB::server addr] eq "10.1.1.2" } {
        set host "2.site.com"
    } elseif { [LB::server addr] eq "10.1.1.3" } {
        set host "3.site.com"
        set host [HTTP::header "Host"]
    HTTP_REQUEST_RELEASE {
    if { [HTTP::header exists "Host"] } {
        HTTP::header insert Host $host
    Keep me in touch. regards,
