Hien_Truong's avatar
Feb 24, 2021
Solved
Cap and not Cap uri
i have the below irule
When HTTP_REQUEST {
if { [HTTP::host] equals " www.abc.com"
switch -glob [HTTP::path]
{ "/App/Events/Calendar.aspx"
{HTTP::respond 301 Location "https://www.def/redirect/Calendar.aspx" }
{ "/App/events/Calendar.aspx"
{ "/app/Events/Calendar.aspx"
My question is how to make this irule simple, can i use string tolower for this case? and how do i apply it to this irule.
Thanks in advance.
    Glad could be of help, would you mind marking the solution as answer provided, so it can help others too.
  • ​i just completed all my test cases after applying this new irule. it works, thanks a lot for your support.
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
