Can Irule forward request after ASM block?
Steve_Knapp
Altostratus
Altostratus
Below is a snippet from an inquiry I received from our web developers. Matching on part of the URI is no problem, but what about forwarding the request even after blocked by the ASM?
So the iRule would have to match on:
  • Portions of the URI that indicate this is an FNOL
  • That the ASM blocked the request
Then:
  • Forward the buffered request to a specific URL
Assumptions:
  • The iRule can buffer the request so it persists beyond the ASM block. This alone may be the show-stopper as this may be a significant performance problem.
  • The iRule can send to a different location than just allowing to pass to the back end pool members
2 REPLIES 2
Andrew-F5
F5 Employee
F5 Employee
"The iRule can buffer the request so it persists beyond the ASM block. This alone may be the show-stopper as this may be a significant performance problem."
◘ I'm not entirely sure what you mean by this?
"The iRule can send to a different location than just allowing to pass to the back end pool members"
◘ You can use a 'forward' command, redirect, etc, after the 'ASM::unblock' statement.
when ASM_REQUEST_DONE { #log local0.debug "\[ASM::status\] = [ASM::status]" if { [ASM::status] equals "blocked" } { ASM::unblock log local0. "Unblocked request with ID [ASM::support_id]" } }
References:
https://clouddocs.f5.com/api/irules/ASM__status.html
https://clouddocs.f5.com/api/irules/ASM__unblock.html
Steve_Knapp
Altostratus
Altostratus
Thanks. Great info!
