MacG's avatar
MacG
Oct 24, 2022
Can DNS-e and GSLB work together?
I'm looking to rebuild my DNS environment to have local HA clusters of F5 DNS Devices using DNS-E to draw from a hidden master. The one part I can't get info about anywhere is whether/how GSLB will interact in this scenario. Should I have the GSLB elements running on the hidden master only? Should I run Zonerunner on the DNS clusters, use DNS e to draw from several sources? Is GSLB incompatible with hidden masters?
Is anyone able to describe if this is possible? IF so what the best practice implementation is please?
