Technical Forum
bypassing ASM from specific source IP
Abed_AL-R
Hello guys
What is the alternative irule for this:
https://clouddocs.f5.com/api/irules/ASM__disable.html
The HTTP_CLASS_SELECTED is not recognized anymore in newer versions
I know it is possible to configure this via regular policy but for this specific situation I prefer irule
4 REPLIES 4
Why do you prefer an irule??
Cheers,
Kees
Not up to my choice
Its shared management environment and its a customer decision
I totally know that whenever there is a chance to solve a problem with a policy, it is the preferred way.
Anyhow, this irule solved the problem:
when CLIENT_ACCEPTED {
   set allowed 0
   if { [class match [IP::client_addr] equals bypass_asm_class]  } {
      set allowed 1
   if { $allowed } {
       #log local0.  "This client IP: [IP::client_addr] is allowed to bypass ASM"
       ASM::disable
      ASM::enable /partition/asmpolcy
Ok. And no policy is attached to the virtual server??
Because that could cause issues. https://support.f5.com/csp/article/K18101546
no, no policy attached
thanks for clarification
