ar0's avatar
ar0
Jan 08, 2020
bot defense -> IBM Qradar issue
Hey all,
I have a problem with data sent from BIG-IP Bot Defense module to IBM Qradar.
I checked it with tcpdump and it seems that some unnecessary characters are glued at the beginning of the payload, disrupting Qradar parser. I tried switching from tcp to udp to no avail. the additional payload is seemingly random.
Did anyone encounter similar problem?
 tcpdump -i EXT-ASA-VLAN -c 2 host 10.111.111.100 and dst port 514 -vvvv -nn -ASs 1514
tcpdump: listening on EXT-ASA-VLAN, link-type EN10MB (Ethernet), capture size 1514 bytes
12:49:54.926122 IP (tos 0x0, ttl 255, id 20545, offset 0, flags [none], proto TCP (6), length 2785)
   10.234.111.165.60939 > 10.111.111.100.514: Flags [P.], seq 3888336727:3888339472, ack 4155562241, win 4380, length 2745
E.
.PA....ls          <---------------this is weird stuff glued to payload
  .o.
....OW....P.......
  <rest of payload goes here>
  • ar0's avatar
    ar0
    that's how it was made
    sys log-config publisher pub-qrad-dos {
      app-service none
      description none
      destinations {
        dest-qrad-dos2 { }
    sys log-config destination splunk dest-qrad-dos2 {
      app-service none
      description none
      forward-to dest-qrad-dos
    sys log-config destination remote-high-speed-log dest-qrad-dos {
      app-service none
      description none
      distribution replicated
      pool-name pool-log-qrad-dos
      protocol udp
    ltm pool pool-log-qrad-dos {
      members {
        qradar:514 {
          address 10.111.111.100
          session monitor-enabled
          state up
      monitor tcp
    (logging profile)
    ext-to-qradar
    [api-status-warning] security/log/profile, properties : deprecated : application/local-storage
    security log profile ext-to-qradar {
      application {
        ext-to-qradar {
          filter {
            request-type {
              values { illegal-including-staged-signatures }
          local-storage disabled
          logger-type remote
          maximum-entry-length 64k
          remote-storage splunk
          report-anomalies enabled
          servers {
            10.111.111.100:514 { }
      bot-defense {
        ext-to-qradar {
          filter {
            log-alarm enabled
            log-block enabled
            log-browser-verification-action enabled
            log-captcha enabled
            log-device-id-collection-request enabled
            log-malicious-bot enabled
            log-rate-limit enabled
            log-suspicious-browser enabled
            log-tcp-reset enabled
            log-unknown enabled
            log-untrusted-bot enabled
          local-publisher local-db-publisher
          remote-publisher pub-qrad-dos
      dos-application {
        ext-to-qradar {
    • The Log Destination is of type "splunk", so I wonder whether the additional data may be splunk specific, but I am not familiar with Splunk logging.
      Try capturing to a pcap, and take a look in Wireshark - it may provide an additional dissection information.
  • ar0's avatar
    ar0
    I tried to change it to other types than splunk and didn't work - I received a warning "Bot Defense logging can only be of Splunk type"... I'll do some more digging and also check on the QRadar side what can be done.
