29-Jul-2023 14:39
29-Jul-2023 19:39
@Ganns This depends on how you are blocking traffic. If you have it logging then you would typically see this in your LTM logs.
29-Jul-2023 19:39
30-Jul-2023 03:11
Hi @Ganns ,
> Review Event logs , if you provision AWAF Module >>> you will be able to see the blocked requests clearly.
> if a specific user complains , run tcpdump for this user IP only to see what happen to him and his traffic flow behavior.
> Review the Packet filteres , if you configure it.
> if much users complian and your service almost down or huge delay in your network :
disable ( L7 profille such as http profile ) and ( use performance L4 virtual server type ) consider any existing irules or LTM policies or AWAF policy attached to this virtual server >>> you will need to disable them too just in the time of troubleshooting and attach them back upon finishing.
