Technical Forum
Custom Alert Banner
Block specific Client IP if request contains XYZ
MaxMedov
Hi, I need help creating the fastest solution (LTM Policy / iRule / other) to do this:
If client IP = X.X.X.X
and request contains = XYZ
Drop the client / or block by WAF message
Thank you!
7 REPLIES 7
Michael_Saleem
Cirrocumulus
Cirrocumulus
For a very quick solution to match on a single source IP and URI, you could use the following:
    if { ( ( [IP::addr [IP::client_addr] equals X.X.X.X] ) && ( [string tolower [HTTP::uri]] contains "xyz" ) ) } {
        drop
However, if you need need it to be more scalable, I would probably use a data group to hold multiple client IP addresses and then maybe another data group or switch -glob statement to match on multiple URIs.
I'd just advise to avoid using "string tolower" on HTTP uri instruction, since path is case sensitive.
Good point 👍
So what is better?
[HTTP::path] or [HTTP::query] should work just fine for exact matches on path/query parts of the uri
If you are using a mixture of upper and lowercase letters in your URI and you need an exact match on this, then remove the [string tolower]
    if { ( ( [IP::addr [IP::client_addr] equals X.X.X.X] ) && ( [HTTP::uri] contains "XYZ" ) ) } {
        drop
MaxMedov
I'll test it thank you!
