Reddy1's avatar
Reddy1
Feb 08, 2022
BIQ-IQ and API (CLI)
Hi ,
We would like to integrate the servers with the BIGIQ so that we can automate few manual processes.
When the server team make any changes, we manually require to disable the pool member on the LTM and then enable it after the server team's work. To automate this, We would like to add a step in the script to make a call to the BIGIQ and disable the pool member and then enable it after the work.
The question is , how to make changes to the LTM pool on the BIGIQ, can we make cli changes on the BIGIQ?
Thanks,
Reddy
