Technical Forum
BIG-IQ - No. Of Devices
RAQS
Cirrus
Cirrus
Hi All,
Hope you all are doing good!
I have BIG-IQ, and I would like to know what is the maximum no. of devices can be onboarded to BIG-IQ.
I think its based on license, but how should I get the exact no. of limitation.
Also, will it count only hardware or both Hardware and Software. I think it will count both but just need conformation.
Thanks in advance 🙂
Regards,
RAQS
1 ACCEPTED SOLUTION
mlwebster
Cirrus
Cirrus
you are correct with the limit been based around your license.
I run a virtual BIG-IQ:
BIG-IQ, VE, Centralized Manager, 30 Instances
I have 10 appliances registered with the BIG-IQ so only use 10 licenses - the licenses relate to appliances - remember VCMP is a license & each guest is also a license.
4 REPLIES 4
mlwebster
Cirrus
Cirrus
Thanks for replying. But suppose i am new to environment and i have BIG-IQ then how would i know the limitation of BIG-IQ with no. of devices to onboard.
mlwebster
Cirrus
Cirrus
Logon to BIG-IQ console <https://BIG-IQ>, select System, select This Device, select Licensing - that will display the license details you've purchased
Thanks mate.
