22-Dec-2015 14:21
Hi;
I would like to provide the windows installation package and the mac installation package with the server URL already built in.
For example let's say I am a user, I download the package then when I install the Edge Client the Server is already prepopulated for me and all what I need to do is supply my credentials.
Can this be done and if yes, how.
Merry Christmas and a Happy New Year Kindly Wasfi
28-Dec-2015
10:42
- last edited on
04-Jun-2023
19:11
by
JimmyPackets
Hi Wasfi,
In the connectivity profile under the "Win/Mac Edge Client" > "Server List" section you can enter an Alias and a Host name. This configuration item is labled as:
Server List - Specifies virtual servers for the connectivity profile. Virtual servers
configured in this list are available from the pull-down list in the BIG-IP Edge Client™.
This seems to be what you are asking for. Update the Profile and then generate your packages via the UI for Win and Mac and let us know if you have any other questions.
-Seth
28-Dec-2015 14:25
Thank you Seth. Happy New year
