Technical Forum
Basic findstr question
quangtran
Cirrus
Cirrus
Hello everyone, I have a request like this:
    "Data": "eyJVc2VyTmFtZSI6ImVjdXN0"
I want to get the data snippet: eyJVc2VyTmFtZSI6ImVjdXN0 , i use findstr code like this:
set data [findstr [HTTP::payload] "\"\Data\"\: 9 \"\ "]
log local0. "raw data = $data"
but return is empty data,
What do I need to change here?
Any and all help is appreciated. Thanks you
1 ACCEPTED SOLUTION
mihaic
MVP
MVP
Here is the findstr document:
https://clouddocs.f5.com/api/irules/findstr.html
you probably need something like this:
set data [findstr [HTTP::payload] "Data"  9  \" ]
3 REPLIES 3
mihaic
MVP
MVP
Brilliant, this is exactly what I needed. Many thanks!
Glad I could help! 😁
