04-Mar-2020 01:48
04-Mar-2020 09:02
Hello,
You can you get the username and the password with HTTP::username and password:
https://clouddocs.f5.com/api/irules/HTTP__username.html
And use Access::session command to set the session variables:
https://clouddocs.f5.com/api/irules/ACCESS__session.html
Then use the variable in the SSO Credential Mapping object. Or.....
Just use a 401 object in your VPE:
