Oliver_Schmidt
Feb 14, 2006Nimbostratus
base64 decoding
I want to base64 decode a 24 character string to a 32 Hex string.
b64decode transfoms the string to a 16 Byte long string
To convert it to the 32 Hex values I use the TCL command
binary scan $v2 H* v3
Example:
set v1 6LCnVil6ib5Df9+6JFiW5A==
set v2 [b64decode $v1]
log $v3
v3 has the value
2756297a89be437ffa245896e4
it should have:
e8b0a756297a89be437fdfba245896e4
binary scan does not work correct.
For some values it works.
Is there another way to do the conversion?
regards,
Oliver
