Chen_Zhe's avatar
Chen_Zhe
Jul 08, 2020
base on HTTP header irules to blocked request
Demand background:
Each request must contain at least one of the four header (has configed at Application Security : Headers : HTTP Headers)
access-token
authentication
authorization
token
my bad rules:
if { [HTTP::host] == "abc.com" || [HTTP::host] == "123.biz" } {
  if {[class match [HTTP::uri] contains meeting] and [ASM::violation names] eq "VIOLATION_MISSING_MANDATORY_HEADER" and [llength [ASM::violation details]] < 12} {
  ASM::unblock
   log local0.info "[HTTP::host] [HTTP::uri] and [llength [ASM::violation details]] and [ASM::violation details] and [ASM::violation names]"
log output:
Rule /Common/authentication_header_url_check <ASM_REQUEST_DONE>:
abc.biz
/dealerUser/auth/login and 5 and {viol_index 64} {viol_name VIOL_MANDATORY_HEADER} {header_data.header_name access-token} {header_data.header_name authentication}
{header_data.header_name token} and
It based on violation names number,Cannot match actual demand。 who has good idea,thanks a lot.
  • Hello Chen Zhe,
    What are you trying to achieve? If you want to block all requests which don't contains any of these 4 headers, then it would be better just create such rule in iRule or you can create attack signature with such rule (e.g content:!"access-token"; nocase; content:!"authentication"; nocase;....)
    Thanks, Ivan
    • Chen_Zhe's avatar
      Chen_Zhe
      Hi Ivan,
      thank you!
      Achieve you guess is right,detail: block all request which don't contains any of these 4 headers,unless shome HOST or host+uri .
      but,rules didn't work as I expected。
      when hit whilelist fist,at the end rules it hit discard again.​
       if {[HTTP::header exists token] or [HTTP::header exists access-token] or [HTTP::header exists authentication] or [HTTP::header exists authorization]}{
         ASM::enable "/Common/base-on-header-string"
      #following all fuction is whitelist.
      if { [class match [HTTP::host] contains domain_whiltlist] } {
       if { [HTTP::host] == "meetingroomip-uat.bba-app.com" || [HTTP::host] == "meeting-inspection.bba-app.biz" } {
         if {[class match [HTTP::uri] contains meeting] } {
       if { [HTTP::host] == "bestyou-uat.bba-app.com" || [HTTP::host] == "bestyou.bba-app.biz" } {
         if { [class match [HTTP::uri] contains bestyou] } {
      else{
      discard
      • Ivan_Chernenkii's avatar
        Ivan_Chernenkii
        I didn't get your further "whitelist" part...
        Do you want not enforce in case of whitelist?.. then you need ASM: disable.
        Also, you have
        which means apply ASM policy in case of at least one header exists... While AFAIU you didn't want to block it. Please, clarify.
