30-Oct-2022 08:22
Please see below screenshot. After F5 bootup, I enter default login name root and password default at the first red arrow, then as prompted, I typied a new password at the second red arrow. but I do not know why it shows Authentication failure, so that I cannot go ahead to next step. Anyone can show experience on this? Thank you in advatage
Solved! Go to Solution.
30-Oct-2022 10:17
Hi davidy2001,
You must enter "default" (current password) at the second red arrow. Then it will ask you to enter the new password.
30-Oct-2022 10:17
Hi davidy2001,
30-Oct-2022 12:14
Thank you very much! The issue resolved!
