Technical Forum
ASM TS Cookie Breaking Multifactor Authentication
WAF_Monkey
Altostratus
Altostratus
Is there a way to disable or remove the ASM TS cookie? This is causing issues with some of our applications. Thanks!
1 REPLY 1
Ivan_Chernenkii
F5 Employee
F5 Employee
Hello,
What ASM TS cookie do you get?
If you want to disable ASM TS cookie you need to disable ASM functionality, which provides it.
If you want to remove it, then most probably you can use iRule for that, but in such case behavior of ASM functionality, which uses this cookie is unpredictable, so I would suggest first option.
Thanks, Ivan
