Technical Forum
Custom Alert Banner
ASM | Reporting - Behaviourial DoS
Amol_Amberkar
F5 Employee
F5 Employee
HI All,
Is their an option to export the report based on Attack-ID detected & mitigated by the B-DoS solution with timestamp of the attack?
currenly was only sucessful to export the reports for last day, week, month - this is not very useful as only the Attack ID's are mentioned without any time stamps
The required info is availble on the dashboard but the ability to export is not present.
Any Ideas on how to achieve this?
Regards !!
3 REPLIES 3
Erik_Novak
F5 Employee
F5 Employee
Yes, you can create a DoS logging profile and send the data via syslog to a remote logging destination. That should give you what you're after.
Amol_Amberkar
F5 Employee
F5 Employee
Thanks Erik.
But that way there is a dependency on the SIEM or the remote logging solution.
Can we not do it via our UI? Or if we want to schedule a report with these parameters?
Asking this as we do have an option to export just that the timestamp is missing and the report then doesn’t make sense.
Do you think we need a feature enhancement request for this?
Regards
Erik_Novak
F5 Employee
F5 Employee
Unfortunately not through the UI. Feature enhancement request is probably the way to go.
