17-Mar-2022 04:58
We have multiple web applications running on a single Virtual server with host/domain based pool routing.
For eg:
red.lab.ae
blue.labe.ae
irule:
switch [string tolower [HTTP::host]] {
red.lab.ae {
pool Red_Pool1 }
green.lab.ae {
pool Green_Pool1 }
Just want to know if i need to apply ASM policy, do i need to apply seperate ASM policy one for "red.lab.ae" & "green.lab.ae" or a single ASM policy for both domain.
Will ASM policy works from top to bottom?
17-Mar-2022 10:30
Hello, you can use ASM::policy syntax to attach a different policy.
red.lab.ae {
pool Red_Pool1
ASM::enable <policy1>
green.lab.ae {
pool Green_Pool1
ASM::enable <policy2>
Regarding your question about using different policies, it very much depends on the portals you're protecting.
I would recommend doing so if the application are very different, as a single "do it all" policy will loosen up the protection because you'll need to enable a lot of things required to make one portal work that might expose threats on the other one, and vice versa.
