Technical Forum
Asm capabilities to decode base46 request
THE_BLUE
Cirrus
Cirrus
i have tried to inject sql injection in my request and encode it , the asm pass the request as 200 . so how can i decode the request to allow asm to read and detect the attack?
1 REPLY 1
IoF
Altostratus
Altostratus
Not sure what ASM version you are on however in Advanced WAF v.15 there is a checkbox for "Base64 Decoding" when defining HTTP Headers or Parameters in the application security policy. Only meant to be enabled it if the value expected is always going to be Base64 encoded, otherwise you will get a ton of violations/errors.
