Cpet's avatar
Cpet
Sep 03, 2023
ASM Bot Defence logs with CEF Format
Hi all,
I have  a cluster with 2 BIG-IPs Ver 15.1.9.1 and i am using the modules LTM + WAF . I found out that WAF bot defence log is with the format Syslog.My SIEM can read CEF (ArcSight) so my question is if there is a way to change the Syslog format to CEF format or if there is possibility to add a unique identifier on the syslog logs of the Bot Defense so those can be read by the SIEM.
