21-Jan-2021 02:11
Hi,'
The Default Pool is set up in APM, not in LTM. However, I would like an iRule in LTM to be also taken into account (the iRUle is setting up the allowed TLS version that is used, that is it!)
Will my iRule in LTM be taken into account ? Will it erase the Pool choice that is set in APM, and therefore mess up my whole config ?
thanks!
Solved! Go to Solution.
21-Jan-2021 08:36
So the irule will only be used for the correct server ssl profile selecting? If that is the case then it will not change any pools you have assigned in APM.
Cheers,
Kees
21-Jan-2021 08:36
Cheers,
Kees
22-Jan-2021 01:35
Thank you!
