Technical Forum
APM variable assignment
AlexS_yb
Cirrocumulus
Cirrocumulus
Hi
I am using client certificate crldp to authorise people.
What I want to do is extract the email from the subject and assign it to
session.logon.last.username
This is what I have come up with - with some googling. not sure if its the best approach
expr { [lindex [regexp -inline {emailAddress=([^, \\\r]*)} [mcget session.ssl.cert.subject]] 1] }
I think if I could use findstr or substr it would be better but I can't seem to call those functions - looks like they are irule and not tcl.
I'm guessing - i found string trim, i could use that but I couldn't get it to work I think because the 2nd arg is char not string !
so then i found string range
so maybe
string range [mcget session.ssl.cert.subject] <> end
not sure what to put in <> to find the position of the string
again back to string trim
https://devcentral.f5.com/s/articles/irules-101-14-tcl-string-commands-part-2
has an example that makes it look like the second parameter takes a string.
0 REPLIES 0
