Technical Forum
APM set network access split tunnel resource variable from iRule
tiltil
hey
i want to put variable in split tunnel of network access instead of ip
i need to
The reason why I want to do this is because I want to put global variable instead of ip address
it is possible?
1 REPLY 1
AlexBCT
MVP
MVP
Hi tiltil,
Have you tried something like this?
I haven't tested the result yet, but the system accepts it and I'm using the same formatting when working with variable-based RDP sessions.
Hope this helps.
