TJMohr_289776's avatar
TJMohr_289776
May 17, 2017
APM Redirect Based on Decision Box Choice
Hello everyone,
I'm having some trouble figuring out the best way to solve this problem. We have a Citrix deployment using APM, but depending on a choice made in a decision box earlier in the APM flow, the user needs to be redirected to a different URI. It can't be all users of the APM profile, only users who are now on the bottom fork of the APM flow.
Decision 1 - https://www.example.com/Citrix/XenApp1
Decision 2 - https://www.example.com/Citrix/XenApp2
I've tried to figure out the syntax for the APM iRule agents, but that doesn't seem to like using the following when starting the iRule with "
when
ACCESS_POLICY_AGENT_EVENT {`" section.
   if { [HTTP::uri] == "/" } {
        log local0. "Redirecting to /Citrix/XenApp2/"
        ACCESS::respond 302 Location "https://[HTTP::host]/Citrix/XenApp2/"
Any assistance would be greatly appreciated!
Thank you,
-TJ
  • Hi,
    you can use this irule without any irule event (not tested).
    when ACCESS_POLICY_COMPLETED {
        if {[ACCESS::session data get session.server.landinguri] equals "/"} {
            if {[ACCESS::session data get session.decision_box.last.result]} {
                ACCESS::session data set session.server.landinguri "/Citrix/XenApp1/"
                ACCESS::session data set session.server.landinguri "/Citrix/XenApp2/"
    this will change the redirect after authentication to the expected URI
