APM Module to do RESTAPI call to a auth server
Hi All,
Is it possible to run a https request to a REST API on a auth server during a log in process?
I need to get further information from a auth server which can be got to from a REST API, just not sure if this is possible.
I have found loads of info about using the REST API to talk to the f5, just not f5 to a REST API somewhere else.
Any ideas please?
Pete
Hi Pete,
I think you are looking for HTTP Connector, a feature that allows you to send an HTTP request to an external API or service. Take a look here: Ask F5 - About the HTTP Connector.
KR
Daniel
