JoeTheFifth's avatar
JoeTheFifth
Sep 27, 2019
APM DecisionBox Customization
I'm trying to add some text with multilanguage support on a decision box.
I used the option1/option2 boxes but I'd like to have additional text outside of these fields.
Any idea how to add an additional field?
I tried modifiying the .inc file but no luck so far.
  • I ended up using javascript like this inside the decision_box.inc file
    <p id="customtitleplaceholder"></p>
    <p id="customtextplaceholder"></p>
    <script type="text/javascript">
    var userLang = navigator.language || navigator.userLanguage;
    switch(userLang.toLocaleLowerCase()) {
     case 'en-us':
      var customtitle = 'en blablabla text';
      var customtext= 'fr blablablabla';
      break;
     case 'en-fr':
      var customtitle = 'fr blablabla text';
      break;
     default:
      var customtext = 'en blablablabla';
    document.getElementById('customtitleplaceholder').innerHTML = customtitle
    document.getElementById('customtextplaceholder').innerHTML = customtext
    </script>
    if you have a better way then please you're welcome to comment.
