APM and IRules
Greetings,
I currently have a vdi setup with citrix on the backend with a f5 apm/ltm in the front to do access policy management. Under citrix web interface there is a logout button that goes to loggedout.aspx. Which I have in the policy as the log out uri so it terminates the session as soon as something clicks the logout button. However there is also a auto log out setup that autologs the user out of the gui which goes to loggedout.aspx?sessionid=xxx. The section in the apm policy sees that as loggedout.aspx so it kills the sesion even if its a auto log out feature. We dont want that as the user can still be doing things. We only want the session killed if its specific to loggedout.aspx and not loggedout.aspx?sessionid=xxx. F5 said that this can be done in an irule which I'm trying to do but I dont think I have it right as it doesn't even allow me to submit the irule through the gui. Any help would be appreciated it.
To summarize the top. I only want the session killed if it matches exactly to loggedout.aspx not if for example its loggedout.aspx?sessionid=xxx. The irule is below. Thanks
