Technical Forum
Custom Alert Banner
after login back to http not https
Anzine
hello expert
How to replace http in respons server back to https, because the server redirect http?
i am trying to find but have not yet the article
5 REPLIES 5
Hi @Anzine ,
Do you install a ssl certificate to your servers ?
Please provide me more details about your Implementation ?
_______________________
Regards
Mohamed Kansoh
Hii @Mohamed_Ahmed_Kansoh,
I have the same problem, so after login the respon from server is http not https. The server that implement cann't be assign SSL because user didn't approved by their management. So, can we improvement from F5 side to make the respons from server to https??  any solution ?
Thanks A Lot.
Leslie_Hubertus
Community Manager
Community Manager
@Satriaji  - I edited your comment to tag @Mohamed_Ahmed_Kansoh so he sees notification to come back to your thread. You can easily do this on your own next time by simply typing @ and starting to type a username (you'll get a dropdown).
Hi @Anzine ,
Could you please Follow this KB Steps :
https://support.f5.com/csp/article/K14775
Regards
Mohamed Kansoh
Paulius
MVP
MVP
@Anzineif an iRule isn't something you are comfortable configuring, another option would be to enable X-Forwarded-Proto using an http profile which is outlined in the following article.
https://support.f5.com/csp/article/K43444200
This will require that the server team configures the server to not issue an http to https redirect when it seems this http header.
