Technical Forum
AFM rule match with actual internal IP or SNAT IP of virtual server?
IRONMAN
Any one suggest me? F5 at gateway connected to internet and acting as a firewall.
Virtual server : IP forward
Destination IP: 8.8.8.x
Source IP: 192.168.x.x
SNAT IP: 4.4.4.x
I need to build the AFM rules for this and apply to global context.
what is order of here, Flow will check the AFM rule or listener first?
3 REPLIES 3
NAG
Hi
Hope this Helps.
Let me know if you have any questions.
Nag
Hi Nag, if i don,t have matching Listener virtual server for same flow with Global context rule allowed for same flow, what would be call?
IRONMAN
Thanks Nag,
I have two questions,
1, I have Virtual server : IP forward , is it act as listener or Virtual server? in Diagram i can see it is has to match listener?
2, In case I have Standard virtual server, How this flow? is it same like, it is check the rule first and go for virtual?
