CX_280703
Jul 10, 2018Nimbostratus
Advanced Resource Assign by iRule or exression
Hi there,
I am trying to figure out how to do an advanced resource assign without having to update the VPE. can you either use a session variable in the VPE setup or can you do this via an iRule?
I am using SAML and want to assign SAML resource but don't want to have to update the VPE every time I add a new one I would like to be able to dynamically assign it using some session variable logic. Is this possible?
